Mstratemann
We bought a used 1999 Seadoo GTX limited which has few hours on it. It has the 947 two stroke engine. Because it had been setting for quite a while it would not start when .we bought it. Since buying it I have replaced all fuel hoses, vacuum pulse hose, drained the fuel tank and inspected the fuel tank. I have rebuilt the carbs using aftermarket kits once and twice I have used Mikuni kits. Have replaced needles and seat with Mikuni sets, set pop offs per factory to 23 pound, have set fulcrum arm height and installed new fuel filters. It does idle fine but acts like it runs out of fuel when you go to accelerate. I have also checked the accelerator pump per the factory manual and it appears to be fine. Also I have visually inspected the reeds and the look good. I am frustrated and need help carbs are set with zero on high speed needles and 1.75 turns on low speed needles. I am quite frustrated have worked on cars racing go karts motorcycles and jet skis very successfully but this one has me dumbfounded. Any suggestions?
