crazeejames
Carb check valves......?? Testing....nevermind please ignore
I'm a little confused............it says to check the "valves" by blowing/sucking on the inlet and outlet nipple of the "fuel" pump............which nipple do they refer to, there is the Fuel feed nipple, and then the two that are side by side with one arrow pointing in and one pointing out, and then of course there is the pulse fitting also. I assume you have to cover one of the nipples while doing this? Can someone please explain which "nipples" I am supposed to be testing.
