noviceskier
Simple question, been looking through the parts diag. and cant seem to find what adhesion used for the carb base gaskets? Or do they go on dry, did a full rebuild on my HX's carbs, new springs, needles, seats, greased up the throttle and choke shafts a little, pop-off at 55psi.
Only thing holding me off from getting it on the water is just to double check with the carb base gaskets since I only bought two. That and a small bundle of small things I need to get done after I install the carbs (bleeding oil lines)
