To add to this, i think the TTO trailtech tach might be the issue. It's very sporadic in it's max rpm readings for me. Best i saw on it was 6720. Right before that it said 6000 and 6500; these were all after a wot run. It has a brand new wear ring, pump seal, 17/22 skat swirl, the raves are cleaned with new gaskets, my water regulator opens and closes smoothly by hand, compression is 150/150, new fuel lines, water seperator, fuel filters and a clean fuel selector valve. I can hear my rave valves open when i go from half throttle to full and there are no hesitations or bogging at wot. Since it's wrapped around the spark plug wire and receives a signal fromt he coil, maybe the coil is the issue, but i can't see that being true for every person using a TTO. The ski runs great from a stop to WOT, so I think I'm going to leave it; it's nice to have an hour meter at the least. The only other thingi can think of is the carbs aren't opening all the way since my finger throttle hits my odi grips. I may cut a notch out of the grip and see if that helps.
OP, did you ever get your issue resolved?
I was just going to update this thread thx.
If you have read all the post, I was on to the rave valves as the plastic exhaust valve threads melted. Got those back together. I took the head off to check cylinders and pistons, they look fine just like last time I took them off. The only thing I did notice, was in the slots for the valves where some grooves on the sides. So I did what I could and filed and sanded them down. Not sure if it did much.
Put everything back together and went for a ride.
Before new exhaust valve, I was running 6450ish with the TTO. First wot it hit 6480ish, and at times 6500. This wasn't making sense to me.
I then took the seat off for a wot run, tightened the tto wire around the plug wire, and as soon as I got going it hit 6720, for a few seconds or 2 before I slowed down. Turned around to shore, wot 6500ish. URG.
NOW get this... My luck with this thing... I decided to try and turn the red cap flush and go for a ride with the seat back on. Didn't start right away, tried again turned over didn't start, NOW it doesn't turn over FML!
I figure the starter is jammed (2nd time this has happen, so replaced the starter last year). A few or more hours later I got it out and unstuck and back together. Those bolts are so dumb to get to. Well same thing, still running around 6450 - maybe 6500. But I raced my brothers (97 spx hits max rpms and has always been faster than mine) and we were side by side. He use to walk right past me, so I figure all is good.
WELL screw it... had a awesome (rough water for my lake today) ride to day, with my gf riding mine, and I was on my brothers. Well after getting soaking wet and having some fun, I went for a rip on mine, and now the rpms are only reading 6200. Which doesn't make any sense, as before the rave valves were fixed and after I fixed the water regulator bellow, it was running constant 6450-6480. URG!
Yes spx800 I was thinking the same thing about the TTO, not being the most reliable way to tell I guess. I think I'm going to try and zip tie it to the plug wire in a few spots to see if that makes a difference. I will also have to try more wot against my brothers, as that seems to be the best way to gauge where it is at.
One last thing (sorry for this being so long), I notice the engine is hotter now, you wouldn't want to keep your hand on it to long. Before with the WR problem and RV problem, I could hold my hand on the engine with out even noticing it was hot, only warm. This normal?
By the way spx800 how do you 'hear' your rave valves open? Neither mine or my brothers I can hear them open.
Thanks for your input!
