C180 Stock cabin Lights
Water Rider
I have a 2005 C180 and had the driver seat cabin light burn out last year. So in prep for this year i decided to replace the bulb. Its a simple task of just poping the little round cover off.
My question is has anyone went with a brighter light bulb? The bulb that came out is a little 12 volt 3 watt that hardly puts out any light. Has anyone stuck in a 5 or 10 watt bulb? They high watts are a little bigger but look like they shoud fit. I am just worried about melting the light case or cover.
also... anyone seen any writeups to add more light in the boat, using the stock dash buttons?
you can swap them to LED's. Try searching on here. LED's draw such a small amount of juice, you can add a bunch and use the stock switch.
