Bypassing Fuel Selector
joaquin12345
Premium Member
Premium Member
I have a 94 seadoo xp and was wondering if it would be a bad idea to use a brass tee and bypass the fuel selector valve. Im having problems with it getting plugged up even with fresh gas and cleaned fuel system. I think the rubber inside is causing the problem. I need to get a new one but was wondering if it would be ok to just connect the open/res lines to the main carb valve or will i be messing anything up???
You can get rid of it ya. Just run the res line to the carb. Just REMEMBER, when your out of gas, your done and swimming back..
Most of the time I run on reserve cause the pickup is at the bottom of the tank and I wont run out of fuel as fast when the machines on its side or upside down, lol.
You could T if you want sure, No problems there either.
