Buying some pieces
That sensor would work for a boat or ski with the 3 wire sensor. Unfortunately I think yours has 2 wires. I made the same mistake.
I have read that, but you can find the correct sensor for under 50, so why bother trying to make an incorrect part work.
If you can tell me on wich site i will buy the correct one for 50 i will
if i google tha part number it cost about 100
I found quite a few on ebay when I needed mine. It doesnt have to be the exact part number. Pretty much any 2 wire sensor will work.
this is wat they send to me today : The #BRP278000970 (SENSOR-SPEED) has been superseded to BRP278000218 (SEAL-WIRE) which is $3.99.
that is much less then 50.
it is olso possible that i don't understand tham well
They gave you the wrong part number. That isnt the speed sensor. That is for what they call a wire terminal seal. Not even close. Someone messed up.
