gazza2010au
i replaced my broken bung rubber seals with plastic seals designed for boats but my GSX is still leaking water i have checked all hoses are clamped tight could the plastic washers be the problem? and how do i remove the drive shaft C shape clamp holding the ring seal carrier in place? as my seal carrier has been moved back and it seems to be stuck are there seals inside of this part?
