If it's still in the hull, I wouldn't. Getting enough heat on the bolts will get everything else hot. You could even ignite the hull if you aren't careful.
I would try to get a little penetrating oil on them. Also, once they start to move... rock them back and forth a few times. That will help break up the corrosion. (and spry more oil on them)
