LiterateStylish
I just bought a 1995 Seadoo GTS. There is a line that's not connected to anything. Guy told me it's a "breather line". Is that true?
Who knows. Post a pic.
Chances are... it's the vent for the battery. They fall off, and people don't know what they were for.
is it hooked to anything on top of the engine?
I see a few other issues... but if it's not hooked to the engine... that was the hose for the battery.
You can't tell from the picture. It's a bad angle. To me... it looks like it was a loose hose, flopped over the engine. I try not to assume things. that's why I asked if it was actually hooked to the head. Telling me "It looks like it", isn't the answer I was looking for.
BUT... on some of the 657 engines... they take the "Pee-Hole" hose from that corner of the head. If that's what it is... then it should be hooked to the nipple by the transom eye, and on some... they run 2 hoses to the pee-hole.
But the other problems I saw were... the 90 degree elbows on the bailing hoses should be supported higher in the transom. With them laying in the bottom of the hull... water will come into the bilge when you are sitting in the water.
Also... there isn't a vent hooked to the battery, that I can see... and since it's a wet battery... it will spill acid into the hull while you are riding.
You battery vent is under the red circle. The nipple for a hose is pointing down. Somewhere in you hull... there should be a hose going from that battery nipple, to the rear of the hull.
Ohhh. Gotchya! Thanks for the info. Does the battery vent hose usually lead to outside of the jet ski?
BTW, I am getting water in the hull. Do you think thats from the bailer issue you were telling me about above (earlier in the thread)?
You may have a pinhole leak in the tuned pipe, it has four welded plugs that rot internally, and at first spring a small pinhole leak.
"flooded" lead Acid batteries require a vent, SLA or sealed lead acid batteries do not.
