Break in on new motor?
tturbonegro
What kind of "break in period" does a new motor require or do. Guys recommend?
Should I do anything specific for the first how ever many hours on a new motor?
(951)
We reccomend you follow the directions of whom you bought the engine, as a warranty issue.
You canot break-in an engine out of water.
Proper break-in of your engine is the most critical aspect for determining the longevity and performance of your engine. Engines not properly broken-in will often fail within the first minutes of operation. Ring failure and piston seizure are the most common symptoms of an improper break-in procedure.
If you have a pre-mix system (mixing oil and fuel in the fuel tank), then you should richen the ratio to about 32:1 for the first ten gallons of gas. If you have an injection system (putting oil in a separate oil tank), then you should put 50:1 premix in the fuel tank along with the oil injection system for the first ten gallons of gas.
During the first 10 gallons of gasoline, there should be NO full throttle operation. First idle the engine for about 10 minutes to ensure that the engine is properly warmed-up. Then begin varying the throttle position up and down, up to 20% throttle for a half hour. Then come back and let the engine cool off completely - it should be a good 30 min break. After it cools down, you may now ride it up to 50% throttle for another half hour or so. Then come back again and let it completely cool down again. Now you can go out and ride up to 90% throttle. Continue this for the remainder of the 10 gallons, never holding one throttle position for more than a few seconds. Do not run at a steady throttle position and do not go to 100% throttle. After your first tank of gas, replace your plugs with fresh ones. For the second tank, you may ride normally with one exception - do not hold it at 100% throttle for more than a few seconds. After the second tank of gas, you are completely broken in and may ride anyway you like.
O wow..that's a lot of info, where did this come from?
It's a 99 951 GSX limited
It has 2 separate tanks
I have seadoo xps oil, is this ok?
And so your saying to mix the gas 50:1 as well before putting in the gas tank? Whats the reason for this?
Any certain type of plugs I should switch to?
Is the tank a 10 gallon tank?
These are Industry Standard New Engine/Top End instructions, and apply to all models with the exception of the DI and 4-stroke equipped models.
Your 1999 GSX Ltd is equiped with a 15 gallon tank
BRP XPS synthetic oil
NGK *plugs BR8ES
Read carefully
