Hey guys/gals,
I'm going to be hopefully borrowing my brothers 2002 Seadoo RX over the July 4th holiday, however the thing has been sitting for ~2years and whether or not it's been winterized I have no idea.
I guess what I'm looking for is what to do/check to see if it'll run without much work. I realize I'll need to:
check/charge the battery
change plugs
fresh fluids (fuel/oil)
This thread: http://www.seadooforum.com/showthread.php?t=14939 suggests that some WD40 be sprayed into the cyls and some additional lubrication of the impeller area.
My brother has the manual which I'm hoping has enough information that I can try to get it fired up in the driveway to ensure it'll run for the 4th. Does the Manual have enough info to "prep" this thing?
Are there any other obvious (obvious to actual owners) tips I should know about/try? I plan to be looking around here over the next couple days to ingest as much info as possible.
TIA for any help,
change plugs
TIA for any help,
