bombardier shut off and wont start
yes we have had the carbs off and apart and the injectionlines were removed before we got it, we were told to mix the gas, and the rotary valve spins fine
we did have carbs off and apart, cleaned them, (wasn't dirty) , oil injectors were removed before we got it, we were told to premix fuel
So it sounds sorta like it's still not getting fuel, if it has the water separator with screw on bowl, those things are known to leak inward and when the fuel pump draws fuel from the tank it also draws air from the (any) leaks in the fuel line, so make sure there are no fuel line leaks.
How about the fuel pump and the fuel pump pulse line(hose) from the crankcase nipple, is the fuel pump working? If the pulse line hose is disconnected or has a leak in it the fuel pump won't work correctly?
Don't forget, the rotary valve is gear driven and the gear runs in an oil bath of 2 stroke oil, so that cavity still needs oil and you have to keep some oil in the tank for that. (just FYI, good to know IMO)
ok I understand what ur saying , but shouldn't it atleast run for a second when I put fuel in carb
I would expect so too, thought that was what you were describing by "it seems to fire but wont run." (ie: fuel+air+chemical decomposition reaction exists and molecules rearranged from HC+O2 -> CO+CO2+H2O)
So, you have squirt(fuel) and squeeze(compression), spark but no bang (of fuel in cylinder), plugs aren't wet with unburned fuel?
Squirt, squeeze, bang, fart, you have the first two of these but no bang?
Then I question spark, could be too weak or even at wrong time.
There are several ways to test for spark, and spark timing, as well. If you have an inductive timing light, you can get a relative idea of both, simultaneously by rotating the engine to where one of the pistons is very near top dead center in one of the cylinders, and make a reference mark on the PTO with a sharpie pen, then connect everything as normal with the timing light connected to the plug wire of the cylinder under test and crank as if starting. The timing light will sense the plug wire pulse and flash, the mark made on the PTO wheel should be illuminated close to where you found top dead center on that cylinder, ie: you should see your mark in the timing light flash just ahead of TDC.
If there's no flash on the timing light, it didn't sense a pulse on the plug wire, thus you have a lack of spark, or if the light flashes but your mark isn't in the flash (because it's around the other side near the bottom where it's impossible to see), then the timing is nowhere near top dead center (maybe 180 degrees out of time?).
That's where I'd start, b/c it's an easy fast test and I have a timing light (I bought this timing light with my teenage lawn mowing money several decades ago). You could just use an inline spark checker as well, to get an idea of the presence of ignition energy to accomplish parts of this, although, just b/c you have full ignition energy doesn't guarantee the plug will fire an air:fuel mixture if the plug is fouled. New plugs should eliminate that possibility.
All these engines use a plug gap of ~0.020", about the thickness of most credit cards. Excessive gap is more likely to produce misfiring at higher engine loads such as full throttle acceleration, where it's most challenging to fire a plug.
