Bogging out
Darryl stahley
Primed the oil line and it's hard to tell if the 2 lines leading to the carbs are full with oil because they are green I did put oil in the tank about 4 ounces to make sure it was getting oil the ski had about a third of a tank of gas. I ran the ski and it was bogging out And it was smoking I was thinking it was getting to much oil so I filled the gas tank to lean it out ran it again and it was still bogging I pulled the plugs and they were full of oil , I checked the oil pump alignment and it seems to be fine is there anything else I can check , I also realized that when I ran the ski I some how skipped putting the air box on that goes over the carbs could this be the reason for the bogging I'm think it might be sucking to much air and maybe the plugs aren't fowling out just have excess oil because of the oil I put in the tank and from priming the oil line
