blower
TVZ1965
Hey guys looking for some suggestions on why my blowers have stopped. I check under the dash and in the engine comparment and their is not a fuse nor one that is blown. going to check now to see if the plug is getting power but it has 2 of then and neither are working.
08 230 Wake Any help would be great Thanks
had the same problem, if you check you got power on both sides of the blower fuse (10amp underneath drivers console if i remember) remove the switch panel and swap connectors with the bilge switch see if blower turns on with bilge switch, i had a bad switch.
there is also a 5amp fuse in a fuse holder near each blower
I ran a 12V jumper from the battery to check and see if it was the blowers or wiring. You should be able to put a meter on the back of the switch and check for 12V.
