rebuilding a 720 in a 97 gti, newbie I didn't squish test and I used grey ultra seal on the base gasket, I was about 2.1MM on the squish test. So order a 4 hole gasket and pull the engine out .. put the 4 hole in dry and reassembled the motor I'm now at 2.4MM, double-checked torque on head bolts and did them to 20Ft Lbs. Motor has new crank new seals , new pistons and rings. How can I be screwing this up?
anyone ?
anyone ?
