Still trying to figure out what my problem is.
Last time I ran this jet ski (96 GSX), the lanyard got pulled and it wouldn't start again (couldn't get the double beep when plugging it in). It set for a while - but put a new battery in it, new plugs, checked all the fuses (which were good).
I still have the same issue, when I plug in the lanyard - I don't get any beeps. I also don't have power to the guages at the moment. I've jumped the starter at the solenoid in the rear electical box. It sparks and turns over.
Just pulled the handlebar apart. I'm still guessing it is a bad post or lanyard - though I'm certainly not a mechanic. Anyway, pulled the handle bar apart and got to the back of the post. I've got three wires coming off of the post. One is black/yellow, another is black, and the third is white.
I've cleaned the post and didn't help. I followed this wire down into the front compartment and found where this harness plugs together. Pulled it apart and got my test light and hooked it to the wires running back to the electrical box. I can get light by putting the ground clip on the middle plug and touching the black/yellow wire plug. That is the only combination in which the light comes on. I've read where you can use a voltmeter to test this switch - but not really sure how to do that.
I've also tried to put it in the self-diagnostic mode (pull the lanyard, push start 5 x). I don't get anything when trying this either.
Can anyone tell me how to check and see if my post is bad (or might be able to tell based on the little info I've given)?
Thanks!
Thanks!
