Hey Everyone,
I'm trying to breathe some life back into a 1995 Speedster that was in pretty rough shape when we started, and have gotten the engines at least reasonably functional, so now it's on to electrical. Based on everything that I have read here, I am pretty sure that I have the diode issue with the MPEM (blowing one of the 5A supply fuses) and plan to tackle that over the winter. But the boat has a handful of other electrical issues, and I am trying to determine if they would correlate with the failed MPEM, or if I should be trouble-shooting them individually. Basically, I don't want to waste any time trying to fix problems that will be corrected when I fix the MPEM (or have it fixed).
The 5A supply fuse that is blown is the vertical one on the starboard side, and the electrical items that aren't working are:
Starboard tach - haven't tried switching the wires to the port tach yet to see if it's a gauge issue.
Bilge blower - fuse is fine when boat is in the on position, blows as soon as the switch is turned on
Bilge Pump - fuse is fine, but does nothing when you turn on the switch. No voltage on connector when switch is on.
All of the switches tested out fine. Does anyone know if any of these are dependent on a functional MPEM? Or do I have a bad MPEM and three other problems?
