Sharkwhit88
I have a 2012 GTX 155 with a power issue. The power relay in the fuse box is staying powered and engaged with no DESS key attached. It is setting a P1658 code. If I put the relay in it will click and cluster will power up and beep. If I then attach the DESS key it wont start. If I leave the DESS key attached remove the relay and reinstall it will beep twice and allow me to start it. I have replaced the relay thinking it was stuck, no help. Disconnecting the battery or removing the relay is the only way to power down the ski. Could the DESS post reed switch be stuck on?
