leepoffaith
I'm looking to change the oil filter in my 2000 GTX. The oil low warning came on this weekend when riding, but we have plenty of oil in the container, so I think the lines/filter may be clogged. Also, I pulled the RAVE valves today to do a good cleaning on them and tried to look at the pistons. They look pretty dry, but I'm not sure what they are supposed to look like. Also, the plugs are light chalky brown and not oily what so ever. Either way, I need to make sure the engine is getting oil. After all the work I just put into this ski the last thing I want to do is blow an engine!
It seems like the oil filter is between the oil and fuel tank and the engine. Of course there is no easy way to get to it. I MIGHT be able to reach it through the glove box hole, but if I can't are there any other ways to get to it? Is there enough slack to take the oil container out through the front of the hull and get to it that way? Also, how do I check if the oil pump is working? Keep in mind, I can barely see the oil pump!
Thanks in advance for your help!
~Lee
~Lee
