TheYeti
I took out the Rave valves last night and cleaned them up. I found them both really built up with hard carbon so I guess they were due. Got the boat last year and only had it out once for an hour or so testing it. Getting it resdy to test out this year now. I found one valve to be ok, all rubber seemed ok the o-ring was old hard and cracked and spring were all there. The other had no o-ring and the beveled adge had a slight bit of a lip on it. Not sure if that could be from a missing o-ring or not affecting the travel? Anyway it all wemt back together for now but the thread on the end of one ohe guilitines were basically stripped. So I had to wrap it repeatedly with thread tape to get it to start enlugh to where it would actually start threading wnough to hold together. My question is do I need to buy a new guilitine or what do I need to do here? Also if I need a new one how do I know which one of the many part #'s I need.
All I know is the boat is a 1997 Seadoo Challenger with a single 787 rotax
Btw I did replace the o-rings as I had an o-ring kit and had some that seemed to fit just fine on the shaft.
