Another question
emtmike
Another question. I hooked the water hose to the cooling system. Is there support to be water coming out of the top of the engine?
Only if you have the water falls special edition engine....:rofl:
Seriously, there should be no water coming out of the engine anywhere. If it is leaking between the head and the cylinder the "o"ring may be bad. You really need to add you seadoo model and year in your avatar for any problems so we have that info to help with advice. Use mine as an example.
Karl
