Another carb question. Sorry yall.
slowboatn
Ok. I removed my carbs off of my 98' GTX Limited. It has the 951 motor. I cleaned them all up real good. I was checking the accelerator pump. When I push the arm down, I can hear air in the carb it is mounted on. Not the other one. Is this a problem? I removed the hose off the carb with out the pump on it and I can hear air through the hose. The injector isn't clogged. I ran air through it. Thanks. I do not have a pop off tester either. Can't afford it right now.
You need some fuel in the carbs to check. The little diaphragm doesn't move enough volume to tell if there is air in both sides..
Ok. Thanks. So put some fuel in and then try it? After the boat broke this weekend we really are fixing to get this thing ready to run. Just no money to do it.
