Alternative to Oetiker
12vman
Hi-
Are there any alternatives to the Oetiker Clamp that I can install without a special tool?
Specifically the 2 clamps between the PTO Rubber Boot. I need to replace the ones I have
as I am putting it back together.
Thanks in Advance,
-12vman
Hi-
Thanks in Advance,
-12vman
Yes, stainless steel ties, you can get them on ebay, I paid about $3 shipped for qt 10. Pull them tight, then clip leaving about 1/4" then grab the end from the side with a very small pair of needle nose pliers and turn under to get it tighter. It'll hold grease fine, and is better than a worm clamp or nylon wire tie.
