Did you bleed it?  There is a bleed port at the pump.  It is kinda slow going, but that should take out the air.  Another thing to do after bleeding it the best you can is take spark plugs out , ground the spark plug wires, hold down the throttle and crank it a little, this will help purge anything left over and purge the lines going from pump to engine.
