Air filter
wampaku
Stupid question but are these cleanable or how can you tell if it needs replacing. Is an aftermarket cone style better or keep to oem?
OEM is better, and it can flow more air than your engine can use. If you replace the filter, you may have to re-tune the carbs since the filter will effectively change the pop-off of the carbs. To clean the element, just hit it with a degreaser, and hot water.
