Air bubble in oil filter!!!
manolocross
So i replaced oil in tank and replaced the oil filter but there is an air pocket in the oil filter!!!!Bled the oil line goin to oil pump and it did not make a differenece. Will this be a problem or am i ok???If not ok how do i get it out?1995 seadoo xp...
If there is air in the line the oil is not gonna flow you need to rebleed it and when you start it hold the oil lever wide open and make sure there is no air in the line
Yep.. you need to get the air out. If it gets sucked down... you will run for 10 or 15 seconds with out oil. If that happens at full throttle... you will roast the engine.
I would clamp the bottom hose, and take the hose off the bottom of the filter. Then hold that end up, to push the bubble out. Then (if you are careful) let the oil flow as you put the hose back together. That way, you wont' have to re-bleed. Regardless... I would add 1 oz/gal oil to the main fuel tank. That way, if there is still a small bubble... the oil in the fuel will keep the engine healthy as it passes. I personally do that any time I service the oil system. A little extra oil is better than no oil.
