Adjusting the trim
hites87
hi there i have a 93 sp and i was told i could adjust the trim by loosening a bolt or nut some where and i cannot find n e where. next question to grease my fittings do i need marine grease or just regular. and where all do i need to grease where r all the fittings thanks again alex
There isn't a trim adjustment on that ski. The HX had a manual trim on the nozzle.
It's recommend to use a waterproof "marine" grease, but as long as the seals are in good condition, the important thing is to keep it greased. (you can use an automotive bearing grease if that's all you have)
