cymertony
I am assuming all the Mercury powered Sea Doo boats have the low speed steering control, which increases engine speed from idle when the steering wheel is full right or full left (to help with maneuvering when docking or trailering). When I first bought my boat in 2021 it only worked when steering to the left. This is one of the things I am most glad to have fixed, since I use this feature every time I go out. Here are my notes on checking operation and adjusting for my 2001 Utopia w/200 Optimax. Instructions are different if you have the 210/240. Hopefully I got my left/right labeled properly... it's been awhile since I did it.
Steering system drawing is on page 49 of the shop manual and instructions for low speed control adjustment are on page 55.
To access the low speed control actuators, you have to remove the instrument panel. First, remove the bow backrest cushion (diagram on page 64, instructions on page 75), then loosen the bolts holding the instrument panel in place and remove to gain access to the steering assembly.
Here's the view under the instrument panel once the seat back is removed. Gauges will need to be disconnected prior to removing the instrument panel.
Here is the disconnected instrument panel:
Here's the view from top once instrument panel is removed:
Disconnect the steering assist sensor cable and connect meter to the sensor side. Set up the meter to measure continuity with the audible beep
Check the sensor when turning to the left and confirm the "feel". In my case the left side was working just fine, so I did not make any adjustment. Note the distance between the actuator and the sensor.
Check the sensor when going to the right and confirm the "feel". In my case the magnetic "actuator" was too far away from the sensor to activate it, so I removed the loctite/sealant and adjusted the actuator until it had the same feel as when turning to the left, then used loctite to seal it back up so it wouldn't move.
All done... put it all back together.
Hope this helps!
Tony
Hope this helps!
Tony
