Hi Folks
As the title reads above I have a few issues that I would really appreciate your opinions on, I will give a brief history of what has gone on so far.. I replaced the rotary drive gear on the engine and it ran like new for a few hours then I noticed a clanking sound and turns out three of the engine mounts were shot.. Question 1 , Are these repairable IE epoxy resin or similiar,,
Problem 2, The next time I ran the machine it started great and ran fine for a minute or two then it would not rev out at all, it would keep ticking over and got me back to shore. then it starts fine and revs out fine on the trailer and does the exact same when I take the machine out again,, I would be fairly good at engines and it seems like an eletcrial fault.. I have tested the MPEN unit and it failed on the black/red to coil test plus a couple of the other resistance tests,, seems like it may be shot.. can these skis be run with the MPEN disconnected as it only seems to control the timer circut , the kill switch circut. from my reading of the circut diagram the power from the magneto goes direct into the Ignition coil and the MPEN only kills. Seems like a scam that this unit is non servicable and cost 200 euros to replace when I can design a simple system to kill the ski when the laynard is pulled ..
Any advice or opinions would be greatly appreciated
