Wanting to rebuild top end. Was thinking it was standard at 82mm cylinder but apparently its not. Inside of piston reads sbt which is aftermarket. Cylinder Measures 3 1/4" which is 82.55mm. Was wanting to buy a top end kit to give to the machine shop while they bore for specs and all but here I was thinking it was standard. Whats the biggest you can goe on these. For a minute thought I could get away with standard size and throw it in because sleeves look and feel good. But you would definitely throw up if you looked at the pistons that came out
