99 xp limited 951
saltybeaver
Hi all,
I found some milky oil in my pulse lines going to the rave's. I am wondering if this is a concern. Where did it come from?
Is there oil in the crankcase I should be changing or is it supplied buy the oil resivor?
Normal. You get moisture in the engine... and oil is always in there... and it just found it's way up the RAVE hoses.
the only oil in the crankcase is the oil in the counter balance shaft compartment which you shouldn't worry about and it does "run" off 2 stroke oil that mixes with the gas.
