CReynoldsMIZ
Can't get my 99 to run right. I'll run it down for you.
142 compression each lung.
Rebuilt carbs, have cleaned them 3 times now, new needles and seats on each one. 36 pop off pressure.
Good battery.
Plug wires trimmed.
New fuel selector, it is 1/4" barbs and the spx uses 5/16"(doubt it makes a difference but thought I would mention)
Accelerator pump squirts and works fine.
Brand new plugs.
Took it out a few weeks ago, it doesn't like to idle at all. Ski is stock and carbs are at 100% stock settings 1-1/2 turns on the lows, 0 on the highs. Won't idle at all, had to keep on the throttle. I have now installed a TTO so will monitor it and I set it on the trailer at 3350 rpms at this moment.
It has a little big if you idle and the full throttle it, but it runs fine after it clears out. Reaches max rpms I am sure. Will check with the TTO next weekend.
But it is a bear to get started in the water, rode it two hours last weekend and never shut it down for fear of getting stranded. It starts not all that easily on the trailer as well, and it seems very cold blooded, meaning it takes some throttling to get it to where it idles nice, meaning if I just started it up it would probably idle around 2400 and die unless I coax it for a little. Once it gets warm for about 30 sec or so it will idle pretty nice a 3350. Reaches full rev on the trailer, got it up to 6950 confirmed with the TTO.
I tested the voltage thinkin it might be rectifier, and it started at 12.6 on the battery when not running and jumped to 13.16 when running. It would not change, not even .01V on the trailer varying rpms all the way to max WOT. Steady at 13.16.
Anybody got any ideas? I'm pretty much stumped. I haven't done the rectifier red wire thing, because that I believe wouldn't allow me to get max rpms on the water which I am capable of, but the 13.16 seems low to me and the fact that it doesn't vary at all has me wondering as well.
Gurus, please share the wealth. I hate electronics, although I'm wondering if excessive rotary clearance might be happening as well.
Good battery.
Plug wires trimmed.
Brand new plugs.
