savesday04
I have a 99 Speedster with the twin 787 engines. The problem is with the port side engine. The starter will engage but there isnt enough power to turn the engine over. If i remove the spark plugs the engine will turn over just fine using the starter so the engine isnt locked. The starboard side engine will start up just fine but when trying to start the port side engine the starter will engage and the starboard engine will die. So im not sure if the starter is just weak and needs replaced or should I check the battery?
Thanks for the help.
