Noahhuotari
Hello all,
The story:
I bought it used for $800 with a trailer. It has 90 hrs on it. They mentioned the only problem was that it blinks 12v low then dies. So I took it home, got a new battery and replaced the plugs. Started right up! So I took it to the lake, paddle on hand and took it for a test drive. Sure enough, blinking red light "12v low" and then it died and wouldn't start. So, I ordered and replaced the rectifer, verified the voltage while running, all good! Took it back to the lake and it was going perfect, no light, running much longer! I decided to see how fast she went and held it full throttle for a little bit, she got up and went good, I let off and it died. It then wouldn't start, it was trying to turn over, but it just wouldn't start. I probably tried a few too many time to start it and drained the battery. Got back the boat back home and charged up the battery, and tried to start *click click click*. So I ordered and replaced the starter solenoid, still clicks. Figured I'd try a different battery, so I got a new one, and same thing. I also took out a 1/2 gallon of water, oil and gas out of the hull.
I gave up and took it to a local shop for them to look at it. Their diagnosis is that the engine is locked up...
They said the pistons looked fine and had no damage to them. They think it's the crankshaft.
They quoted me about $1,200 to replace the crank shaft and about $1,400 to just replace the engine...
My questions are:
What about the starter?
What could have caused this to happen?
Is it even worth fixing or should I dump it and spend the $1,400 on a different boat?
Thanks!
The story:
My questions are:
Thanks!
