98 Speedster Twin 800's Pls Help!
jeffdiedrich
Hey guys and girls, I just bought my 1st seadoo boat 2 days ago and today was the 1st day on it. Ran great for about 20 min then it started slowing lossing power so i popped the back and looked and the left engine, On the exhuast there is a rave valve looking thing and its dripping water out of it!? so i wait a few minuted start the engines back up again and it goes great for 10 sec and then both engine wont rev past 3rpms. Seems like the longer i shut if off and let it sit the longer it will run like it should, .. 5 min of sitting = 30 sec of normal engine activity, 1min of sitting= 5 sec of normal engine activity.. Honestly i have no idea about these boat i came from a outboard. Oh yeah one more thing if this helps is my oil light is on but i still have alittle past the " Min " mark on the tank.. Is there a safe mode? what could this be?? why is it leaking out of that rave exahust valve? thanks for the help! One more then The BEEP BEEP isnt working when i plug in the key..
think you need to do compression test on motors. Water should not be in there (raves,...black caps, with red dots). Maybe just a bad base gasket or o-rings in topend.
I dont know if there the RAVES or not...
I dont know if there the RAVES or not... Its not the raves on the engine its the thing that looks like a rave on the exhaust i see 2 hoses going to it with liquid. ?! that black thing is leaking out of the middle...
got it, thats the water regulator. That, shouldn't be leak'n. While in the engine bay, pull the motor raves, and clean those, take ya, 15min.
