98XPLTD Denver
Ok I’m looking at replacing my stock sponsons. Who makes the best aftermarket sponsons for this ski ? And where to buy them please.
Thanks
Thanks
You can make your own out of aluminum for about $50.Ok I’m looking at replacing my stock sponsons. Who makes the best aftermarket sponsons for this ski ? And where to buy them please.
Thanks
Block off the front hole because the hull curves in and the aluminum won't sit flush.
Piece for inside the hull use 1/8th inch thick, 16 inches long, 1.5 inches tall.
Back piece that goes against the hull use 1/2 inch thick, 16 inches long, 1.5 inches tall.
For the actual sponson use 1/4 inch thick. You can make it any design you want.
For my sponson I took a piece 1/4 inch thick, 18 inches long, and 3.5 inches tall.
Measured 4 inches to the right from the top left corner and put a mark, then draw a straight line from that point to the bottom left corner and cut it. Then measure 4 inches to the left from the bottom right corner. Mark that and then draw a straight line from that point to the top right corner and cut.
Then I used a belt sander to round all your edges and then polished them....will powder coat when I have time.
I will post mine below.
3 Pieces. Piece that goes inside the hull (1/8th inch), one on the outside (1/2 inch) and then the sponson (1/4 inch)Wow looks good I hadn’t thought about making my own. So it’s two pieces then?
Oh nice yes I don’t have anyway to cut that. Would they be pre drilled for my 98 XP LTD? I was thinking bright yellow to match the ski color.I showed tyler how to make them. if you want a set we can make them. I can even powder coat them to what color you want. let me know if your serious. you would be around 150
yep you would just have to take the old ones off and install the new ones. i would make sure you had all new hard wearOh nice yes I don’t have anyway to cut that. Would they be pre drilled for my 98 XP LTD? I was thinking bright yellow to match the ski color.
Hmmmmm I might have to just get a set from you then. How do they perform over stock? Any pics ?yep you would just have to take the old ones off and install the new ones. i would make sure you had all new hard wear
You really wouldn't want sponsons like that on a standup. To get it to turn better look into tubbies.Hmmmmm I might have to just get a set from you then. How do they perform over stock? Any pics ?
Do you do any for Yamaha stand ups ? I was looking at some thing for my 95 Yamaha FX1
Gotcha good thing i asked. I’m interested in possibly getting you to make me some yellow ones. Let me know how they look and Perform if you can.You really wouldn't want sponsons like that on a standup. To get it to turn better look into tubbies.
Sorry that’s supposed to be for glsmohio lolGotcha good thing i asked. I’m interested in possibly getting you to make me some yellow ones. Let me know how they look and Perform if you can.
Do you have any pics I might just purchase from you then.yep you would just have to take the old ones off and install the new ones. i would make sure you had all new hard wear
We have them for all of our X4’s but I’m the first one in our group to make them for an XPL....I rode today to test my ski but was too rough to try any sharp turns.
