jpiotrowski
Hey everybody just trying to get some fresh ideas what to check, front cylinder 140, rear pto 129PSI, rebuild the carbs, replaced the fuel lines, replaced cracked top exhaust pipe, it's a hard start, and runs bad when running, when I remove the spark plug wire from the front cylinder, almost impossible to run on, will run on rear cylinder, notice oil leaking around the base gasket. I replaced spark plugs, the spark looks strong on both plugs, sprayed carb cleaner to get engine started. Possible issues that I'm thinking to check, leak in fuel line or filter cup, leaky cylinder base gasket, reed valves, dirty rave valves, always looking for fresh ideas. Thanks.
