Grim
I had an issue come up and want your guys opinion on causes. I was at the river the other day, went out on a ride to a place that was 15 mins away, straight drive at around 30 to 35 MPH, to a hang out place. Stayed there about 2 to 3 hrs, then went to crank it up to come home and it threw the 12 volt low error message It was turning over (with choke) but wouldn't crank. I used the throttle a little and was able to crank it, drove back at same speeds, no issues, no 12V low..
I put it on the meter today and cranked it up, no 12V low . Here what I saw. The meter was at 12 .18 volts , when I started cranking it, it went down to 9.65 and bounced around . The highest it got was 10.45V. After I got it to cranked and at idle I had 11.8 to 12.3 volts (bouncing around those numbers). I revved it between 5000 to 5500RPM and it went up to 13.3V....steady.
I think either my battery is bad, I bought it Nov of last year, or the voltage regulator is dyeing!. Any chance it could be the stator?
I thought I saw where OSD made a attachable voltage regulator, since my model has the built in regulator. Is that a good options, is it worth it, does it work right? I will also get my battery load tested, just to make sure. Lastly, should I do the stator checkout??
Am I on the right track, did I forget anything? any advise?
