Pulled the plugs and attempted to rotate the rear flywheel shaft with an 18 inch pipe wrench, not a budge. Last time I used 90 days ago, flushed engine with water, fogged oil thru carbs while running, shut off water and punched throttle a couple times to clear any remaining water and shut down. Pulled plugs and fogged cylinders and cranked it over a couple revs then parked it in under the shed. Location is about a mile inland from the Gulf of Mexico. I usually run in the gulf but the river inland begins getting brackish by the time I reach the boat ramp. Ran great and no clue there was anything thing wrong. Five years ago my rear piston was seized by heat, according to STB. Replaced the blocks and rebuilt the carbs, jet pump, fuel lines and all hoses. Has run great since. The only things I can think of are: rust built up in the cylinders and the piston rings are rusted to the walls, the jet pump bearing(s) are seized, however I would think I could at least feel the slack in the spines of the drive shaft and something on the crank is seized. I want to avoid pulling the engine so any troubleshooting and ideas appreciated.
