Took my newly acquired 98 GTX limited out and it cranked fine. Put it in the water, and again it cranked and idled fine in the water. When i gave it gas it would start to accelerate and when it hit about 2k it would die out. But recrank. Verified nothing was blocking the intake. Pluged up a water hose after taking it out of the water and cranked up again. And at first began to bog down as it would in the water, but finally wound out. Ran it for a couple of minutes. Noticed alot of black suit material on the ground from the exhaust. Put it back in the water still same result. Cranks right up, idles fine around 900-1000k but when you give it gas it bogs down after hitting around 2.5k.
Any help would be apreciated.
