so i got 1998 seadoo gsx limited 951 carb oil pump deleted its a premix
i got the air silencer from ebay assemble it adjusted everything to manual setting on carb, carb was rebuild base on previous owner.
the issue i got is the ski dies on acceleration but if i rev it few pumps it goes fine if i let throttle go and ski still move but not idle speed it will accelerate on spot no engine die or anything.
so i set the carb to factory setting high it close the low is 2 turns out, my question is if i wanna do it right what i do first do i set the throttle cable first or do i set the idle rpm first?
i know it nob question but no where it mention what to set first rpm or throttle cable.?
manual said 2 turns out for low speed but the website for sea doo setting said is 1-1 1/4 which one is right?
thanks for all the help im on my way to the lake as i write it hope will get some input by the time i get there
