98 Challenger pulling to the right
Sea Tan Tan
98 Challenger pulling to the right? It has the twin motors, I checked the nozzles & they are straight with the steering. So I'm wondering if it could be one of my wear rings? When I go max rpm 7000 and cut the left motor back to around 5000rpm she will steer straight? I looked at both wear rings with a flashlight from front & back, I don't see any difference no chips or damage that I can see? Could the right side wear ring be just wore out? Or is there some other reason for this? Any help/input would be great.
It seems to pull hard to the right? Does that sound right, with the rpms between the two motors to make her steer straight?
if you are in it by yourself and all the weight it on the right side of the boat, along with what Dr.honda says.... it will pull to the right. but I am heading outside right now to check if my twins are lined up right with a long level
