Heat from a propane torch around the threads on the PTO is typically needed to break the thread lock. Heat it until the paint starts to smoke a little. Don't worry about the crank seals because you are going to replace them.
Okay, got the crankcase all open and there is another spot of surface rust on the crank that I didn't notice and the crank seals look new. You guys told me I wouldn't have to re do the timing, I don't understand how that could be. I took everything apart and tried to check everything over. The crank rotation all feels really tight.
Is there anything else I should check?
How should I got about cleaning the surface rusts in those two spots?
What do I need to know about putting it together?
Can't really post now I'm driving. I never use heat. Yes thing Crittenden on what you took apart you will need to time stuff but it's easy.
You will need to time the crank and balance shaft together, but the flywheel has a keyway so will just go back on the same way as before. The computer gets its ignition info from the flywheel. You can find info on timing the balance shaft in the factory service manual, which you can find on the web, or become a premium member here and they're available for download.
no, do not use that on the crank. Just keep posting pics of your posts in question. We can't see what your looking at so you need to help is help you. We like pics here so do be shy.
That's the rotary valve for engine timing, piece of cake to do manual shows you how
Nope, there is a degree wheel you can buy or there's a pdf you can print to make one which I didNeed a special tool?
I'll get back to you later. Had ice hockey, then soccer, now of to get a nee milling machine, compressor and bead blaster. Just a little tied up right now.Cool deal.
Well racerxxx,
Got anything for me on the rust?
I actually uploaded the better of the two by accident. Here's the worse one. But just wipe with it with two stroke engine oil?
I would CAREFULLY oil the rust, then with a brass bristled brush work the heavy rust AWAY from the crank journals lightly then wipe it down and possibly a quick blast of wd-40 to wash it off, then a little wipe down. The rust isn't really that bad but I do see a little on the edge of the inner bearing, so if that bearing doesn't feel too smooth it might not be long for life. But it looks good from what I can see.
Yes it is true. Please post a picture of the connecting rod small end bearing surfaces.
Chester
