pulled the carbs off yesterday and replaced the diaphram on the fuel pump and also the black gasket as well cause it was not getting fuel now it is getting fuel.. but dying off i will pull the carbs again and go through them do you know the setting for the carbs???
alright...pull plugs, maybe water still injested in case. Pull the RAVES (black caps on motors) clean them, clip plug wires back 1/4in, at the boots ends, and install new plugs.
thanks alot they were caked with gunk i took them out n cleaned them both really good and its now will runn i think i still need to adjust the carbs a little though its ideling kinda high. should i clean the third one thats not on the engine ?
