sabotage10
Last weekend I took out the spx and it was running 100% until I did a few 360's and was gagging the throttle with my big 215lbs ass. All of a sudden the power dropped in half. I pulled her up to the shore and noticed it was full of water so I drained it and kept the seat off and started her up and gave it a little gas and noticed that where the motor and rear drive shaft bolt up together (with that black plate that mounts to the hull) that water was dumping into the hull, but only under throttle. It was also making a louder rattle then it typically does. I figured that the two wing nuts holding it together were loose but they were as tight as they can get. Is there a gasket between the rear drive shaft and this black mounting plate that could be gone? What procedures should I take to figure out the problem and what is the problem more than likely?
