sportsfreak90
took my jet ski out to the lake today and had the following issues that I've been trying to resolve:
Starts great when it's cold, won't start very easily once it's hot.
If you go from idle to any throttle under 1/2 throttle, runs fine. if you go from idle to half throttle or more, it bogs for about a second and then takes off.
I have adjusted the low speed needles from 1/2 turn out (lean) to 1&1/2 turns out (rich), none of which helped with the hot starts or the bogging.
I was reading the Carb Adjustments thread and was reading that the High Speed Jet could possibly be my issue? Would I adjust the High Speed needle to fix this problem? The carbs have been 100% blown out and cleaned twice with carb cleaner, removing all the jets and needles and filters with replacing ALL of the fuel lines so I know none of that is my issue.
Thanks! I really appreciate all of the help I have gotten so far on these forums!
