97 Speedster-Lost it's guts
waternuke
Hey I have a 97 speedster, twin engines. It runs generally good, but just seems to not have the same towing power as it did a summer ago, hard to get skiers up slower to plane off. Without skiers or rafts with just passengers it will still do 50! Also this boat never took on any water, now it does everytime out? I've changed the plugs and cleaned the fuel filters? Any thoughts. Thanks.
Are the engines making the rpm as before? If it's reving up but not accelerating it could be that the pumps are cavitating. Too large a wearing clearance or sucking in air from your leaking driveshaft carbon ring.
Have you done a compression test to see what's going on inside the engine?
You'll need a compression tester. Go to Auto Zone. I think they sell for like $25.00. The compression gage, will screw in the cylinder head in place of the spark plugs. To test compression, remove both spark plugs. Place spark plug caps on the plug cap studs near the cylinder head to ground the empty caps. This completes the circuit of the ignition electrical system and prevents any electrical problems from the caps being un grounded. Using the correct adapter for the threaded end of the tester,( same length of the spark plug threads length)screw in the tester in one plug hole. Hold the throttle wide open. Push the start button. Watch the compression guage, when it peaks out at the most compression, let go the start button. Read the psi number. I would do it 3 times to be sure it is accurate. Check both cylinders the same way. The ideal compression is 150 psi per cylinder. If it is less, it's not a problem as long as they are close to being the same. If the psi is less than 90 it might need be time for a tear down and a rebuild. If the psi in 1 cylinder is say 140 psi and the other is 80 psi you need to tear down and repair. This difference is a lot then there is a problem.
I hope this helps you.
Karl
