D discount New Member Jun 14, 2010 #1 hello took carbs off and cleaned carbs, change all fuel lines around carbs and ones i could reach, put 2 new plugs,in still have to water test, im going to clean rotary valves. how tight do you turn the plastic on to the rubber o-ring ?
seadooya Premium Member Premium Member Jun 14, 2010 #2 what rotory valves? Theres only one, which is under the intake manifold. No need to clean that. Not following you, with the plastic onto the rubber o-ring...
