OEM wear ring with 40 - 50 hours of use. Impellor is a Skat Trak swirl 16/21. I am experiencing cavitation under heavy load which is caused by the damaged portion of the wear ring. However, what does normal wear ring wear and tear look like? I have read that it is normal for the sides of the ring to be worn while the top and bottom are virtually untouched. Is this because of flex in the plastic pump? The Impellor still looks like new with no signs of any damage. I have a new driveshaft (original bent by tangled rope), New carbon ring, replaced pump bearings and shaft.
https://drive.google.com/file/d/0B6ImiKvEXBlkNlhNSmZ0NW5yaUk/view?usp=sharing
https://drive.google.com/file/d/0B6ImiKvEXBlkUGNsT1QtX09Sd0E/view?usp=sharing
https://drive.google.com/file/d/0B6ImiKvEXBlkeFhxT29hLUtnS1U/view?usp=sharing
The stock wear rings are fitting much looser than before. The ring does not slip but didn't require much effort to pull out of the pump housing. Time do drill the pump housing and screw the next liner down? I frequently pull a wake boarder and find the OEM ring suffers performance degradation. I am considering either a SBT Delrin or WSM stainless liner.
Here in British Columbia OEM wear rings are $78 after taxes @ the dealer. Delrin wear rings are not available anywhere and must be order from the USA. I can purchase WSM Stainless wear rings from Ontario for $96. On average I put 100 hrs or more a year on the Seadoo
